주요 콘텐츠로 건너뛰기
The Black and Decker Air Station is a 160 psi air compressor that is designed to inflate a range of household items.
2 질문 전체 보기
Air station quit working
I a ired up one tire then hooked my air station to another tire but the air station would not come on.I checked all I could check but it still would not come on.What can I do?Did the ac dc switch suddenly go bad?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
My air station will not blow up my tires. It blows air when not attached to the tire. HELP
댓글 달기
답변 1개
I just got me one of these at goodwill for $40 and I wish I had my money back! Your Air Station stopped working because the fuse blew just like mine did only the second time I used it. And guess what? I had to take it apart to get to the small fuse inside and this is a pain in the ass because you have to cut out the old fuse and solder in a new one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi,
There's always a reason why a fuse blows, so don't be ssurprised if it happens again very soon.
Fuses blow because excess current is flowing through them due to a problem in the circuit that they're there to protect e.g. short circuit turns in the motor winding or a component that has changed value for whatever reason.
What is the model number of the device?
댓글 달기
귀하의 답변을 추가하세요
george m denison 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 47
전체 시간: 1,132
