주요 콘텐츠로 건너뛰기
1.83, 2 또는 2.16 GHz Core Duo 프로세서
281 질문 전체 보기
질문 마감됨
Boots fine, login screen is streaked through the middle.
About a month ago I replaced my hard drive, not sure if the two are related, but it worked fine for a few weeks, I upgraded to snow leopard and was very pleased. then one night it freezes, and ever since it boots fine, then at the login screen there is streaks across the screen through the middle. Sometimes I am able to log on, but after any other function or about 30 seconds it freezes. I know it's hardware because i targeted and the software functions fine. Any ideas? is it the harddrive? logic board??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
선택된 답변
So, after some research and some help from lemerise, I found that this problem is fairly common with the ATI radeon X1600. I found some screenshots that look exactly like my problem. Solution? Replace the logic board. at least a $500.00 fix. Apples recommendation? Buy a new computer. Bummer! Thanks for all your help. Guess I'll start saving!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Yes the GPU seems to be the culprit. Do you have the Nvidia GeForce 8600M GT graphic chip ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
No, It's the ATI Radeon X1600. I did another teardown just to make sure everything was buttoned up right and aftwerward I still have streaks but I can use it without it freezing unless it sits idle for any extended period of time. Strangely, on youtube for example a video played in the browser has streaks through the browser, but when i enter fullscreen they go away! so next step in try replacing the GPU?
댓글 달기
Try running the apple hardware test
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I agree with rab777hp582 about the AHT, but personally, I've never had it pinpoint a hardware problem. So I don't consider it definitive if it finds nothing wrong.
You can rule out the hard drive by booting to something else--the system DVD (such as when you use it to run the hardware test) or an external drive. If you still have problems, then it's some other part of the hardware.
Make sure you've done the requisite resetting of the SMC and zapping of the PRAM.
http://support.apple.com/kb/HT3964?viewl...
Sometimes a really sick hard drive will cause systemic problems even when you're not booting to it, but this does not sound like one of those cases to me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks. I did run the hardware test, I guess I should have mentioned that, and it said everything was ok. I will try resetting the SMC and zapping the PRAM because I've never heard that before. It is a brand new hard drive so I hope it's not sick, but I also know it wouldnt be the first.. thanks again for your responses..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,404
