Sim stuck in slot
Sim card stuck in slot deep
Xperia z5
Not on the sim tray
Iv got that out
I didnt know what it was for
좋은 질문 입니까?
Xperia z5
Not on the sim tray
Iv got that out
좋은 질문 입니까?
Last time this happened to me, I stabbed the sim with an exact knife and pulled out slowly. Took a try or two but worked
해당 답변은 도움이 되었습니까?
Brother Robert thank u soo much bro. ur comment helped me and i successfully pulled out my sim. JazakALLAH !
If the phone doesn`t have a push/pull configurations, then the sim would`ve stucked inside a tight space. To remove the micro sim, you will need a small piece of metal that can slip into the micro sim slot and then push it outside so that it would go out. Don`t try to press it forward because it will just make it harder to get out. If you don`t want to damage your phone further, simply go to the nearest Sony center which will they will do it for you for a fee of their service.
해당 답변은 도움이 되었습니까?
Mine is stuck as well in th sim port but I've tried a needle, I've tried tapping my phone around but it's still stuck and Sony says that it isn't covered under manufacturing defect so they won't do anything. So I'm stuck with a phone that can't be used as a phone because the tray will only fit halfway in. Is there anything I can do?
해당 답변은 도움이 되었습니까?
This thread was really useful. If you look carefully you will note the there will be some space on the side of the card, as the SD slot is wider. I have successfully used a paper clip to take the SIM card out without much trouble.
>> Push an unwinded paper clip inside on the side of the SIM card and fish it out. <<
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 12,117
댓글 1개
My sim card is stuck inside Th the phone still, I can't seem to get it out, I é tried everything lol I'm not good at this kinda stuff
Douglas I Vargas 의
