주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z5 안드로이드 스마트폰은 2015년 10월에 출시되었습니다. Sony Xperia Z5는 5.2인치 1080 x 1920 픽셀 디스플레이를 특징으로 하며, 퀄컴 스냅드래곤 810 프로세서와 3GB RAM, 23MP 후면 카메라를 탑재하고 있습니다.
Sim stuck in slot
Sim card stuck in slot deep
Xperia z5
Not on the sim tray
Iv got that out
I didnt know what it was for
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
My sim card is stuck inside Th the phone still, I can't seem to get it out, I é tried everything lol I'm not good at this kinda stuff
의
댓글 달기
답변 4개
가장 유용한 답변
Last time this happened to me, I stabbed the sim with an exact knife and pulled out slowly. Took a try or two but worked
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Brother Robert thank u soo much bro. ur comment helped me and i successfully pulled out my sim. JazakALLAH !
의
댓글 달기
If the phone doesn`t have a push/pull configurations, then the sim would`ve stucked inside a tight space. To remove the micro sim, you will need a small piece of metal that can slip into the micro sim slot and then push it outside so that it would go out. Don`t try to press it forward because it will just make it harder to get out. If you don`t want to damage your phone further, simply go to the nearest Sony center which will they will do it for you for a fee of their service.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Mine is stuck as well in th sim port but I've tried a needle, I've tried tapping my phone around but it's still stuck and Sony says that it isn't covered under manufacturing defect so they won't do anything. So I'm stuck with a phone that can't be used as a phone because the tray will only fit halfway in. Is there anything I can do?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
This thread was really useful. If you look carefully you will note the there will be some space on the side of the card, as the SD slot is wider. I have successfully used a paper clip to take the SIM card out without much trouble.
>> Push an unwinded paper clip inside on the side of the SIM card and fish it out. <<
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kc 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 11
전체 시간: 12,581
