주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
535 질문 전체 보기
Rear cover will not lift off MacBook Pro 17" Unibody
I have removed all of the screws from the rear cover of my MacBook Pro 17" (i5 128 SSD).
When I proceed to try and lift off the cover it appears to be secured in the middle of the cover...which is really odd.
Is this held by tape, a hidden screw, a clip? How do I proceed?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Turns out there's just two clips in the center that the rear cover clips into. With gentle force it will pop off after the 10 screws are taken out.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Good catch Josh. Now please accept your answer to clear the question. +
댓글 달기
I had the same issue.
Trouble is, how do I re-attach those clips when re-assembling the computer?
Update
You are correct. Just press the back plate against the Mac's innards. It will click. Thanks a lot.
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
For personal attention please start your own question so you don't get lost in an old question.
I was told by a Genius at the Apple Store that the clips should re-attach once the back case is on and the machine is flipped back over with gentle pressure on it.
Seemed to work for me when I put in an Optibay to replace my Optical Drive with more HDD space.
댓글 달기
I have the same problem. The issue is that those 2 clips fit into 2 little bracket type parts that are screwed to inside of the case. One of mine is broken (plastic middle part) It is to unscrew it. But I can not find anywhere where to buy this little piece of plastic
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Josh Rubinstein 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,083
