주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and disassembly information for laptops manufactured by ASUS.
Keyboard back light is always on
My laptop keyboard back light is always on.
Only when my laptop is asleep or turned off the back light.
I tried to use the normal method - fn f3 - not working.
I couldn't find a property in the computer that can change it.
Thank you, good luck.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개:
Hi, What is the model number of your laptop and what OS is installed?
same problem, tried many things nothing.
Hi @Edgar Ghazarayan,
Try installing the latest Asus ATK package and Smart Gesture drivers and check if that resolves the problem.
Be sure to install the ATK Package first before installing the Smart Gesture.
Also do not be tempted to install any other drivers from this link (not yet anyway). Work on one problem at a time. As the saying goes, if it ain’t broke, don’t fix it ;-)
I tried it many many times, tried older drivers and newer ones and still nothing. I thing that problem is not that simple yet it is not some mechanical problem.
댓글 달기
답변 1개
Good luck!
I wish I could get my Dell keyboard to stay lit longer than 10 seconds when not depressing any keys.
  • When did this first occur?
  • Have you looked at the Administrative Events?
  • Do all your keys function properly?
  • Have you checked your owners manual/PDF
  • Have you tried reverting back to an earlier driver through the Device Manager?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It happened after i gave my laptop for service bcs of blue screen.
How to look at administrative events ?
All of the keys function properly.
Checked owners manual
I tried reverting drivers, i tried reseting pc to factory settings.
I need some serious help :D
Hi @Edgar Ghazaryan,
How long since you took it in for service?
If it was working before you took it in and not after you got it back from service, take it back and show them the problem.
Do you know if they had to open the laptop to fix the blue screen problem?
If they did then it may be a hardware fault caused when they were fixing the screen problem.
댓글 달기
답변을 추가하세요
blabla234 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 1,673
