주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
Only works with speaker activated.
When making or recieving a call I need to activede the speaker on my Iphone othervice the I can't hear and the reciever can't hear me.
What do I need to change?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
The most common source of this issue is debris in the headphone jack causing the sensor inside to continually detect headphones. This in turn forces the phone to turn off the receiver earpiece and mic. The most common source of this debris is pocket lint, BTW.
You can also test this by playing a track in iPod mode - if it doesn't play thru the speaker, and the volume control indicates headphone adjustment with no headphones connected, then the sensor is being triggered.
Try blasting compressed air into the headphone jack in a series of short blasts. The debris can also sometimes be cleared by repeatedly inserting and removing headphones from the jack.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Have you taken your iPhone apart? If so, it could be that ribbon #3 is out of place- that one corresponds to the earspeaker.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How far is the #3 cable supposed to go into the phone? it looks as if there is a white line with an arrow pointing to it. Should it go in that far, or only until the "light" colored brass in all the way in?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i dont think it goes all the way to the line, well i couldnt get it that far and it wasworking fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 6,606
