이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi, Are you having problems sending to only 1 other particular fax machine or to any other ones? If it is to only one other fax machine the problem may be at the other end. If it is to any Fax machine, perhaps your Fax Transmit level is set too low. Also if your fax machine is connected to a telephone line which also has an ADSL connection (internet) on it have you filtered the Fax machine's line connection?
jayeff 의
