주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
85w charger on a 13-inch MacBook Pro Early-2011 without a battery.
Is it possible to use a 85w on a Macbook Pro 13 inch (early-2011) that does not have a battery. I would like to run it on AC only.
I am currently using the original 60w charger and the Macbook does not turn on if there is no battery. I am not sure if the 85w will help in this case.
Does anyone have experience with this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I have an 85watt mag-safe on my bench. I use it to power any Mac-book that comes in. It have an end adapter for the newer machines. Some MacBooks need a battery installed for little extra boot power but most 13" machines will boot just fine. The link XTerminal give says, "You can use a compatible higher wattage adapter without issue, but it won't make your computer charge faster or operate differently. Lower wattage adapters will not provide enough power." You date and time my be lost without the battery if left unplugged for a while.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
No Mac books use the battery for main power, and the charger alone does not power the device.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Here is some info to help you understand
https://support.apple.com/en-us/HT201700
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Quang Nguyen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 1,682
