주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
Black screen with backlight works on out-screen only in recovery mode
Hi,
I'am trying to solve a problem with a 13" MacBook Pro retina system of a friend of mine.
If I start it up it doesn't show any image, just a black screen, nothing more.
If I use HDMI output with an external monitor it doesn't show anything either.
The only way I see something is when in the recovery mode (cmd+r) and only thru the HDMI connected external monitor. Nothing can be viewed on the MacBook Pro screen.
I hadn't opened the MacBook to check things out. Instead I went to an Apple retailer, they told me it's the retina screen, but I think they are fools and is something more with memory or the graphics card.
Does anyone have a clue here? I would like to try to buy a new assembly but is expensive.
I've tried resetting the NVRAM using CMD+Option+R+P. Tried a backup, did a new OS installation, nothing worked here.
Just after the software reinstallation and relaunched through its SSD (in the recovery mode) it shows me the White Apple logo and only though the HDMI connected external display and then nothing more then a white screen and goes no where.
Thanks to anyone who could give me some suggestions!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Can you give us some background here what happened before the system failed. What the system dropped or did something spilled onto it?
Is it the i7 logic board?
have you found the reason and managed to solve it?
@Bartosz Blimke - We've got a great mystery book here, missing the last half so how did the story end?
Sadly, the OP never gave us enough to know.
Its best to create your own question if you really want to know the ending of this great mystery! Here's the start point! Ask
댓글 달기
답변 1개
가장 유용한 답변
I suspect you do have something more here than needing a new display. But without more information its hard to answer what is needed.
I would start off by opening the bottom cover and do an inspection looking for liquid damage or burnt parts. I would also make sure the connections were fully seated (with the battery disconnected first).
Take some pictures if you see something odd. Compare your system to the images here: MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement.
Don't forget to ask your friend what happened. Any clues here can help.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
i expect no damage on display, i think it is something about mainboard, maybe logic video or some small parts, do you think is there someone able to replace this parts?
Sure but what?? Not enough information to offer you more here
I think I have the exact same problem :/
I can't boot the machine without the external monitor.
I can boot in safe mode and in recovery mode, but once I disconnect the hdmi / mini dvi cable and reconnect again, I can't see anything on both screens.
Last time I went to a mac shop they told me it was nothing and it was working ok. I have to pay 40€ only because they ran some tests on the machine. Now I got the exact same problem and I have no clue what's the cause :|
댓글 달기
귀하의 답변을 추가하세요
leluu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 800
