주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Damaged Chip on MacBook Pro ( A1502, Mid-2014, Retina, 13")
Hello all,
I was recently cleaning my motherboard (820-3476-a) from water damage using isopropyl alcohol and an antistatic brush and damaged a chip. It is completely gone - like can't even find it.
TL;DR: Please identify the grey chip missing in my attached photo (white arrow pointing to missing chip).
After hours of research, I ended up with a boardview and schematic, but the schematic is not easily understood and my .BRD file will not open in any programs that were suggested. Now, I found both of these files separately on random forums, but many people had responded an verified that the boardview file worked.
So, if somebody can please help. I can send you the schematic and .brd. I just need the chip model number to send to a friend who does micro-soldering.
Thanks.
Here is the .brd that I'm having trouble with: https://drive.google.com/file/d/0BxX337h...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
@skinnys this answer is not to diagnose your board but just to identify the component. That is L7870 which is a 2.2UH 2A 0.155ohm inductor in a 2512 package. Remember there is a reason why it did blow up. check for short circuits etc. Looks like Mouser.com as well as Digikey.com carry those.
해당 답변은 도움이 되었습니까?
점수 4
댓글 7개:
Thanks! This is the closest item that I could find that matches your description on Digikey (note, this is my first time to search for this type of product):
http://www.digikey.com/product-search/en...
looks like it should work.
Great, so just order that and have it soldered on? Also, I can't seem to buy less than 2,000 when I choose the quantity to add to the cart.
Let me see what I can find....
Any news on that chip?
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
scott randolph 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,595
