Could my battery break by dropping the phone?
I dropped my phone and its now dead. Is it possible that the battery could be broken, as its not showing any continuity with a electric current tester.. the power switch appears to be working (has continuity).
Thanks for any help.
Update (04/22/2016)
It was the battery. Bought a new one from Fairphone (back in stock!) and worked immediately. Job done!
좋은 질문 입니까?
댓글 2개
Hi, Testing the battery, with it isolated or not from the phone, you should get a voltage reading using a Voltmeter connected across the battery connections, if everything is alright. Is there anything showing on the phone when you connect a charger?
jayeff 의
Hi, Thanks for your reply.. no there is nothing showing on the phone when I connect the charger. The phone comes on when you connect a different battery (I used wires to connect a nokia battery from the battery terminals to the connectors in the phone).. and also there is a voltage reading from this nokia battery when isolated from the phone. . All this points to a dead battery from the Fairphone I think? Trouble is their batteries are out of stock!
emma beattie 의
