주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
iTunes/computer wont detect iPhone after battery replacement
Replaced the battery after iPhone 6 plus suddenly died and wouldn't turn back on, Now the iPhone is turning on but stuck on a boot loop.
iTunes recovery and DFU mode is not being detected by the computer (tested on 3 different computer with 4 different cables)
I've replaced the battery twice, replaced the lightning port twice, made sure the battery was at 100% and tried every button combination out there but nothing! (iPhone has never been Jailbroken).
Here is what I don't get, whenever the new battery is connected and i try connecting the phone to the computer with the lightning cable the iPhone turns ON (just like any iPhone when it detects it has been connected) if the port would be bad that wouldn't be happening,
if you can help me figure this one out or can fix it for me I would appreciate it
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Maybe you knocked off a component for the data lines while replacing the battery.
댓글 달기
답변 1개
선택된 답변
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Boot-loopers are the worst...
Normally I would say that replacement charge ports and batteries are notorious for low quality. However, you have already tried multiple parts to no avail so that isn't the problem.
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
Otherwise, many things can cause a boot-looping device. Give us more history by commenting on this answer.
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
izou1838 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 847
