주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
597 질문 전체 보기
질문 마감됨
Install of Win10 failed with BootCamp 6
I have a model 1286 MacBookPro 9,1 and the UPGRADE to Windows 10 worked on it from the previous installed Windows 8.1 PRO ...
But installing on a new SDD failed with Boot Camp 6 later, any idea what could be the problem ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Who's SSD is in the system?
MINE ! ;P
( Samsung SSD 850 EVO with 1TB )
댓글 달기
답변 1개
Using an external Mac OS-X bootable drive open Disk Utility and reformat the disk to GUID patition map and create a journaled file system partition for the Mac OS. Once done install a fresh copy of OS-X onto the SSD. At this point I would make sure the systems firmware is up to date. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Make sure you are at the level listed or newer. I would also make sure the OS updates are also applied at this point.
Here is the Apple page which goes over the process of setting up Windows with BootCamp: Boot Camp Support
And here is a link to the Windows drivers you'll need: Accessing the Windows drivers via Boot Camp Assistant app.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 615
