주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Right antenna damaged during screen replacement
I damaged the right antenna (right side of the home button) during screen replacement. Is this part available? How will the ipad function with it damaged?
Update (05/01/2016)
Its the wifi version. I did find the part on Amazon, expect to get it in a day or two and will install and test out my repair.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I have this problem as well, but mine is the LTE model. Do I still need to get the GPS Antenna Flex? Or is the right antenna a different part on the LTE model?
댓글 달기
답변 2개
가장 유용한 답변
Is you model the LTE or WiFi?
What is the extent of the damage? Have you completely severed the cable? Post pictures if you can.
As to whither or not it will still function, it might, the iPad has two combi WiFi/Bluetooth antenna, but it might not have the range it had.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yes the antenna is replaceable.
You have damaged the "GPS Antenna Flex".
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
What is the part number for this?
댓글 달기
답변을 추가하세요
Andrew Curtis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 523
