주요 콘텐츠로 건너뛰기
Released in 2007, this version of the A205 series includes an Intel Core 2 Duo T5300, 1GB of RAM, a 160GB hard drive, and a basic DVD burner.
5 질문 전체 보기
laptop freezes when charger is connected
Hello everyone....
My problem when I connect the charger and windows 7 was opened ,laptop will work for a few minutes and after that will stop working ...nothing work no mouse,no keyboard... And If I want to close it I cant do that by power buttom just take out battery .....and if laptop closed and adapter connected will not work just leds light work ..and screen is black..please help me
Sorry for my bad english
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hey @com_mad, I did some research on this issue and the known problems with these Toshiba Satillite laptops is a bad capacitor called NEC/TOKIN Proadlizer. You can replace the capacitor or temporarily use your computer in safe mode.
To replace the capacitor:
http://www.laptoprepairblog.net/toshiba-...
One of the ifixit users @oldturkey03 suggests this
Try this work around, until we can find a permanent fix. In SafeMode Go to control panel--> device manager---> go to processor----> disable one of the two processors --> reboot normally. Or you could try to disable your processor there. see if that will make a difference.
More techniques if none of the above work can be found here:
Freezes whenever AC plugged in
-Let me know if this helps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
almunzir alhassan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 17
전체 시간: 1,238
