주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
touch screen systematically unresponsive after any wake up?
Hello,
I replaced my iphone 5s screen and afterwards I have this systematic issue. Every time you hit the power/home button to wake it up, the touch screen is unresponsive. Simply pushing the power button twice (sleep then wake back up) results in a fully responsive and functioning touch screen. This occurs basically any time the phone has been asleep for longer than a minute - I haven't systematically figured out the exact time.
Does anyone have any ideas what is going on? I have turned the phone off and back on, same issue remains, and it has persisted for the last week.
Thank you for any assistance,
Jake
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 달기
답변 4개
가장 유용한 답변
Hey jolson1129, disassemble and reassemble the display. Here is the guide for that. Also try a hard reset by holding the power and home buttons together until the screen turns black and the Apple logo shows up. Also if it doesn't work then the display might be faulty and you might have to replace it.
-Let me know if this helps.
iPhone 5s Screen 이미지
상품
iPhone 5s Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I think it's either a force restart, or its lacking in gigabytes, and just needs more time to think...
Thanks for the responses.
It's not a time thing (as in memory like you suggest), I can wait however long after pressing the button and the touch screen. Also, the issue didn't exist before installing this screen. Hard reset didn't work. I'll disassemble and reassemble, but I don't understand how this could be a connection issue - does anyone have any idea what kind of issue it is? Almost seems like a capacitance issue. Could help to suggest a fix if someone had an idea on the cause.
@jakeo I think the display is faulty. To confirm this, you should reassemble and disassemble it. If the issue still persists then you should replace it.
댓글 달기
Hi jolson1129,
I'm having exacly the same issue with a Iphone5s, did you you ever found out what was the easy fix for this issue? I just restored the phone and keeps doing the same.
Cheers
X
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I don't remember what I did, I believe I just I'll disassembled and reassembled. I believe that solved the issue.
댓글 달기
I have almost exactly the same problem as well: If I have my phone off for more than a few minutes, the screen is mostly unresponsive unless I sleep and wake. It will respond to some touches but not most, and it’s bad enough that I can’t even swipe to unlock. I have not replaced the screen on my phone. Rather this issue started randomly one morning after sleeping on it. My headphone was pressing into the screen. A hard reboot didn’t fix anything.
I also thought it might be something to do with capacitance, like sleeping and waking was discharging something. However I bet it is a faulty connection corrupting some controller, and sleeping resets it. If opening it up and wiggling around the connection works, I’ll post here.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Opened up my phone to replace the battery, which required disconnecting the screen entirely. It now works perfectly! I'm guessing the digitizer connector was loose. You can follow the steps from the ifixit guide for replacing the battery on an iphone 5s.
댓글 달기
Thanks for the good ideas to bring it. I know a lot more. :)
[url=http://www.ufa007.com][color=#e1e1e1][size=1px] พนันบอลออนไลน์[/size][/color][/url]  :J
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jolson1129 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 43
전체 시간: 3,843
