I can barely see the screen
I can barely see the screen and adjusting it makes no difference
좋은 질문입니까?
좋은 질문입니까?
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
이 답변이 도움이 되었나요?
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
Did you replace those?
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 536
