주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Is the front glass the same as the 6.?
Are the 6s and 6 front glass identical?
Im about the start glass only repairs and was wondering if the glass I've ordered is correct because they've Sent me glass that is identical in every way to my iPhone 6 glass.
Can anyone confirm for sure before I start laminating my 6s lcds to it? Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
No. Different materials have to be used to allow 3D touch, and the exact dimensions may differ although I have not confirmed it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The front replacement glass dimensions (width and length) for the iPhone 6 and the iPhone 6S are the same. The glass for the 6/6S will both fit into a iPhone 6 LOCA/OCA refurbishment mold.
What to watch out for:
The thickness of the aftermarket glass varies from vendor to vendor. The home button holes may be smaller not allowing proper fit of the home button. In the early days of the iPhone 6 glass coming out some where a little longer and would not fit into the mold. Some of the 6S glass my be a little longer from time to time depending if the manufacturer has got their tooling right.
The force touch is controlled by a sensor behind the back light. The glass has nothing to do with the force touch function. Though I imagine a thicker glass will have a slightly different feel(the type LOCA/OCA does make a difference on force touch).
My solution:
Dry fit your aftermarket screens into the mold after you receive them from your vendor. You can do this with the plastic covering on. Because you need that plastic covering on to keep the glass super clean before laying that glass down, especially the inside facing the LCD. Have a stock OEM home button to check the home button holes (just stick it in) or buy a dial caliper and measure. Why? Because let's say everything goes right and you are getting ready to put the screen on a phone and the home button doesn't fit, all that time and effort is wasted. Been there!
That's all I can think of right now. Feel free to ask any question you might have.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Neil Davis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 164
