주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
No service on phone but ICCID shows in About
I've got an iPhone 6 where it constantly looks for service.
I've tried 3 different sims.
The SIM card shows in the ICCID field under Settings > About.
I've swapped the logic board into a new phone case\shell where that housing\cellular previously worked, however, I still get no service.
Is cellular service linked the the logic board somehow?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 8개
Is your phone locked to a specific carrier?
I don't believe so, is there a way I can check? Searching via google only brings up those scams to pay for unlocking service.
Well I use sim-unlock.net to check these stuff. Costs like $5 to check via imei number so I don't recommend doing though.
Is there really no other way?
Boggles my mind to be honest. The old school symbian OS nokia phones were a dream to work with compared to these. :\
You have checked that the date and time is correct on the phone right?
댓글 3개 더보기
댓글 달기
답변 3개
선택된 답변
Of course the cellular service is linked to the logic board, why else would you put a logic board in a phone?
It is likely to be dead power supply to the transceiver chip, or dead transceiver chip.
해당 답변은 도움이 되었습니까?
점수 5
댓글 6개:
I've noticed that the cellular antenna is in the charger port piece.
This makes me curious if it's something else, somewhere else.
Are you able to go into a little more detail re~ transceiver chip?
There are 2 cellular antennas, it is not possible for them to fail at the same time.
So it must be a chip problem.
Hey Tom Chai, are you able to locate these for me? on a schematic or diagram?
Basically every chip on the lower half of the board, it's way too complex for ppl without the experience or tools.
댓글 1개 더보기
댓글 달기
Check IMEI via *#06# and if no IMEI is displayed then you have a issue relating to baseband chip.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
In "about" do you have an IMEI number?
해당 답변은 도움이 되었습니까?
점수 2
댓글 11개:
Yes I do have an IMEI in Settings > About.
It does does all detect the sim as it shows the ICCID
I've come across the same issue, this is usually due to the housing you've used. I found personally that using an aftermarket Housing is the wrong move, use only an original / OEM Apple housing if you can and you shouldn't have the issue.
I've used a legit apple housing?
I'll try testing with a different iPhone 6 housing (OEM apple) and test to see what happens.
From what I've been told / seen, and what the research suggests, there are no Original New Housings available for purchase / use, only second hand and maybe A-Grade aftermarket? That's just what I've found in my experience
Ahhh Sorry, I meant I've used housings from broken screen phones where the logic board has been removed but everything is in tact (sometimes screens are missing too)
댓글 6개 더보기
댓글 달기
귀하의 답변을 추가하세요
Nigel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 3,747
