주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 3월에 출시된 Canon EOS Rebel T3i는 SKU(SKU:5169BO32)를 통해 식별할 수 있습니다. EOS 600D 및 EOS Kiss X5로도 알려진 이 카메라는 1,800만 화소의 Canon 디지털 SLR입니다.
Camera won't turn on
I was using my canon 600d camera and suddenly it just died, I mean turned off by itself.. I presumed it was the battery so I fully charged it. Unfortunatley it is still not turning on. Any solutions for this?Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
make sure the media card slot door is closed and secure properly..there are points on the door that go into a slot when the door closes and triggers the camera to know its closed..the camera will not turn on if the door is open or not closed properly..
의 공유
댓글 달기
답변 3개
I have the same problem , i checked it and the dc board ( Power board ) has broken
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My issue was a corrupt SD card. Try removing your SD card first and power on your camera. This worked for me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There are also small tabs on the CF card door and the battery door that depresses a switch when closed. On my camera, this tab was broken off and no longer pressed the switch. The parts are small and not obvious but will keep the camera from turning on if they are missing (broken).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
michaelmusong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 43
전체 시간: 2,640
