주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Coaxial port damaged affected anything?
Hi all,
I was changing the LCD on my 6s when I noticed I have knocked off the silver metal part which holds the Coaxial cable in place for this upper port below...
The actual black/copper socket is still connected to the board though, I have used a little glue to hold it in place...Can someone please tell me what this port actually does? The phone is operating as normal, I cannot see any traces connected to it either.....
I am not convinced this is an antenna port. Please click the link to see picture.
[IMG]http://i63.tinypic.com/ipukqp.jpg[/IMG]
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Yeah I mean all works fine so..Just trying to figure out exactly what it does.
Yeah I am just trying to figure out exactly what it does as I have checked for traces on the board and there are none.
댓글 달기
답변 2개
Depending on whether the phone is GSM or CDMA (AT&T/ T-Mobile or Verizon/Sprint, respectively), that is an antenna port. I know that the GS4 CDMA and GSM phones are different in the same way.
I would suspect that to be either Wi-Fi or GPS/alternate cellular. Test it out...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
That is the wifi diversity antenna connector. The phone will lose some wifi reception and the link speed can drop 50% in some cases.
이 답변이 도움이 되었나요?
점수 0
댓글 7개:
Okay thanks for that are you 100% sure? My wifi still works fine but maybe I repaired the connection very well? Wifi signal also good. Mainly full
That is the "diversity" antenna, the performance loss is not obvious unless your broadband gives you extremely fast download.
Ok, where is the primary and secondary cellular antenna located? Could you please provide some links to pictures?
Thanks!!!
Primary cell antenna is the lower connector flex and lower bezel, diversity LB and MB antenna is the top bezel, HB is the antenna module on the top left.
Thanks for your quick replies I am online now so good to see this news. Can you please explain what LB/MB/HB is?
댓글 2개 더보기
댓글 달기
답변을 추가하세요
michael 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 254
