주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm에서 출시한 이 즉석 카메라 모델은 이전 버전보다 더 얇고 가벼워졌습니다. Mini 8은 권장 조리개 값을 알려주어 촬영을 도와줍니다. 또한 하이키(High-Key) 플래시 모드가 있어 부드러운 인물 사진을 촬영하여 멋진 결과물을 얻을 수 있습니다.
My Instax won't work
My instax switches on, all the red lights around the lens shines at once and when I click the button to take a picture, nothing happens.
It's definitely not the batteries.
Please let me know how and where I can fix this problem
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 5개
선택된 해법
According to the camera's user manual, the batteries should be replaced with the camera switched on, which appears anti-intuitive because with most cameras exactly the opposite is recommended.
Quoting from the troubleshooting section of the manual:
Replace the batteries. only when the power is turned on. If you replace the batteries while the power is turned off (when the lens is retracted), the lamps on the brightness dial blink after turning on the power even with new batteries
Try the following: with the camera switched on, remove the batteries, then reinsert them. If the problem persists, the camera might indeed be defective and it is recommended to turn the camera off and remove the batteries immediately, then have it checked by a repairperson.
Note that you must use prime quality batteries in this camera. Fresh alkaline batteries from a reputable manufacturer are recommended. Be wary of cheap batteries bearing prestigious brand names, these may be counterfeits and will not perform well.
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Thank you for your response, but I started the camera as explained on the trouble shooting. Step by step.
I had new batteries inserted, I even tried Duracell AA.
Do you know where I can repair this camera? I am based in Cape Town
의 공유
I don't have the faintest idea as I've never been in Cape Town :)
However, your best bet would be to ask around locally. If you know any photographers, ask them where they take their gear for maintenance and repair.
의 공유
Hey I'm facing the same issue please help
의 공유
Hi I have the same issue with our camera. All lights are on and it won't go off even if I change the batteries and the film
의 공유
Ever resolved ?
의 공유
댓글 1개 더보기
댓글 달기
Daughter's camera has the same issues. Went thru 3 different batteries. Doesn't
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Did you check shopping malls and Camera stores ? Check online and call local camera stores. One another way is buying from ebay.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi - Same problem here after less than 4 shots.
If it's less than a year old, send it in for warranty. You will need the receipt (just printed it from, amazon), and they will direct here: FUJIFILM Repair Form (fujifilmusa.com). Send that with the camera to the address on the repair form.
FUJIFILM Camera/Binocular Repair
1100 King Georges Post Rd
Edison, NJ 08837
For any questions, you can contact them at 800-800-3854.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I found there is a trick to change the batteries with the camera switched on. At least with my unit. What worked for me was taking the batteries out and putting them back on WHILE pushing the ON button. Push the button all the way down and keep it pressed while you take out the batteries and put them back in. Should be good qualuty new batteries.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shihaam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 52
전체 시간: 47,253
