주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Battery problem? (Percentage issue)
I have an iPhone 6 bought in 12/2014 and in March this year started to have some problems related to the percentage of the battery when it is near 20/25%, the phone turns off and says "no battery" but if I try to power on, fifth/sixth attempt later, boot with is 20/25% usually, sometimes the battery jumps from 25% to 10% and stuck on that until the battery really reach 10% when I connect the charger the percentage back to their normal, it all started when I upgraded my iPhone from iOS 9.0.2 to 9.2.1, I tried to clean install iOS 9.3.2 on iTunes but the problem continues ... this can be a problem in the battery or is a bug on iOS? I have less than 500 charge cycles.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
It shouldn't be that bad.. But then again Apple likes to do this kind of thing. I got my 6S on release date, and the charging port is already going bad. You could change your battery... I haven't heard anything about the new iOS hurting battery life..
iPhone 6 Battery
iPhone 6 배터리 교체하기
iPhone 6 Battery 이미지
상품
iPhone 6 Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Battery life is not the problem, the problem is the phone turning off with 20/30%, i think i will try replace my battery, Thanks!
댓글 달기
found this blog http://www.etradesupply.com/blog/how-to-...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thought connecting to wifi would auto fix that...
댓글 달기
You can also try by using an original charger. Keep in mind that when you purchase an iPhone which is not brand new, the charger is not always an original one. So try to purchase an original iPhone charger and things would get better. If this helped you, follow me on IG @like_kyriee and i will follow back.
Regards,
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Heitor Scatolin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 4,139
