주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
467 질문 전체 보기
upgrade CPU E7600 to E8600
Hi,
I'm still using my late 2009 27" iMac for simple tasks.
The EMC 2309 was offered by Apple with either a E7600 or E8600 CPU (both Core 2 Duo) 3.06 or 3.33 GHz
Today the E8600 CPU chip is very cheap (about $30) I've read that it's about 20% faster than the E7600
As it was offered by Apple, and knowing that the processor is socked on these models. Is it possible to replace my E7600 by E8600?
I have not found an answer on the web.
Thank you in advance
Mise à jour (22/05/2016)
thank you very much for your answers.
I don't matter about the amount of work, it's mostly for fun
If I try myself to change the CPU, is there a risk to ruin definitely the computer ?
Thank you !
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It's a lot of work as you'll need to remove the logic board out of the system. It is risky job and yes, you could kill your system if you mess up installing the chip.
It's still best to just upgrade the RAM & drives first. Trust me ;-} I speak with experience here.
댓글 달기
답변 2개
선택된 답변
Yes, you can upgrade the CPU to the E8600 Core 2 Duo CPU. But given the amount of work and risks I'm not sure it makes much sense here. I would point out the amount of memory and the HD offers more performance benefit than replacing the CPU if you haven't done anything yet with them.
I would push the system to 12 GB and look at upgrading the HD to a SSHD or if you want to go a step further, go with a dual drive config using a SSD. Here are the IFIXIT guides:
Here's the SSHD hybrid drive if you replace your current HD: Seagate Desktop SSHD. You will need this as well: OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade.
iMac Intel 27" EMC 2309 and 2374 Hard Drive 이미지
안내서
iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
난이도:
운영
40 minutes - 2 hours
iMac Intel 27" EMC 2309 and 2374 Dual Drive 이미지
안내서
Installing iMac Intel 27" EMC 2309 and 2374 Dual Drive
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 2
댓글 10개:
I don't understand how that is possible if the E8600 has a 333 higher bust speed?? I thought it would be incompatible?!? but people say it works, I don't understand how.
Well... It really isn't running at the higher clock if all they did was swap out the CPU chip alone.
I.E. a race car stuck on a regular highway vs a race course!
You need to alter the logic board clock setting as well which requires a bit of soldering and a few jumpers and resistors.
I personally don't recommend it! Its just better to tackle the easy improvements: Max the RAM, Upgrade the HDD to a SSHD or SSD. Given the limitations of the system OS wise I think that's as far as I would go.
I just bought this E8600 processor based on this post.
So now I'm hearing it's "NOT" ACTUALLY compatible. Without serious modification.
So if I just swap the E8600 in, does it boot and work properly? or are you saying to reach full bus speed, it requires serious modification
Define working: It will fit and the system will run! But, it won't leverage what the chip was designed to offer! Its not worth it!
Take the time to review the schematics for the board to see how Apple (and many others) design a single board to support multiple CPUs.
To be clear I didn't recommend it in my original answer! "But given the amount of work and risks I'm not sure it makes much sense here"
By "But given the amount of work and risks I'm not sure it makes much sense here" I assumed you just meant, it's a pain to take apart for minimal performance gain.
I am a professional. I repair and fix computers for money. Taking apart a computer into a soup or parts across a table, and. putting it back together, isn't a hassle for me. I am tearing this Mac apart regardless for a GPU upgrade to a
Radeon 4850, and while it's apart, I'd like to swap this CPU in, and apply new thermal paste to the entire system.
댓글 5개 더보기
댓글 달기
Sorry, if the CPU is user upgradable on this model, it would be just a matter of swapping it out, but I do not believe that it is.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You are correct! It's more than a CPU swap out! You need to alter the logic board clock. Apple used the same logic board with different clock settings.
댓글 달기
귀하의 답변을 추가하세요
Gerard Bricault 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,867
