주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
How do I check the ignition unit?
Craftsman Riding Mower model number 917.259566 how do I check ignition unit off the engine with ohmmeter?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@durwood that will depend on the engine of your mower. According to the manual it should be a Briggs & Stratton Model 42E707 Type 2631-E1 Any chance you can verify this?
댓글 달기
답변 1개
가장 유용한 답변
@durwood the only sure way to check the Magnetron ignition is to use the Briggs ignition tester (Briggs part # 19368) and follow the instructions. The tester takes into account the effects of compression and gives a real representation of what is taking place while the engine is cranking or running. Briggs and Stratton does not provide any electrical specs for the Magnetron due to some electronic components inside the unit that cannot be separated from the rest of the circuits for any external tests. So you either see if you can get the tester or take your chance on a new Magnetron.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
James Hudson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 131
