Why is my front right Indicator not working,bulb ok
I have a XL1200 Harley Davidson Sportster 2012
It came on yesterday 9/6/2016 as i was turning right,then suddenly went out and on dashboard little green arrow flashing rapid?
좋은 질문 입니까?
좋은 질문 입니까?
Check the rear bulb as well when one goes the other acts weird so check to see if the rear bulb is bad
해당 답변은 도움이 되었습니까?
Thanks Jim i will check rear indicator just in case that is the fault.:)
Sam "little green arrow flashing rapid" is caused by the indicator not working. Make sure that the bulb is indeed okay, I'd replace it anyway. If a new bulb is not working as well, check the wiring going to the indicator. Make sure that it shows continuity.
해당 답변은 도움이 되었습니까?
Funny enough the indicator decided to work in the rain,touch wood its still working now,but i will check back indicator like you said,thanks oldturkey :)
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,584
