Black line down the middle of the screen
My Samsung 48 inch TV screen has a black line going down the middle of it.How can I fix it
좋은 질문 입니까?
좋은 질문 입니까?
jamesfry817 sounds like a TAB error on your LCD. Put some pressure on the tabs on top of the LCD where the line is and see if pressure on that changes it. It might help if you post an image of what you see with your question. That way we could see what you are dealing with. Use this guide for that. The TABS are at the end of where the little ribbon cables, that go from the LCD controller board, into the LCD panel.
해당 답변은 도움이 되었습니까?
How do u fix tab error
@lightbeauty a TAB error is very difficult to fix for a DIY'er. This is where the ribbon cables enter the actually LCD. Those cables are bonded (to the panel. If that bond fails your cable no longer makes contact with the LCD panel. Sometimes some electrical tape or even duct tape may exert enough pressure to close that connection. If that does not work then there is not a lot one can do to fix it. This will of course depend on where it failed, how much has failed etc.
I have the same issue with a black line in the center of my screen
james schoener most likely the same issue.
This seems ro be happening to all curve samsung big screen tvs. Including mine and it is new out of the box. Why isnt this a manufactors recall?
24 시간 전: 38
7일 전: 177
30일 전: 784
전체 시간: 166,872
댓글 23개
I have a samsung 50" model #PN50C430 and i have one line vert and one hor i just wonder if you new what was causing this
wadegoulding 의
wadegoulding those are commonly caused by TAB errors. If you take some picture and post those with a separate question we can probably ashow you a bit more
oldturkey03 의
Hi I have a 55" Samsung smart 3d tv. There is a thin black time just down from the centre of screen. It runs from left to right. What is causing this
Carlena 의
So I have a 55 in hdr tcl. And I left my PS4 under the tv and I guess the magnets in it left a black lil hole at the bottom of my tv and now there’s a black line showed on it. Is my tv destroyed or is there a solution
paul720m 의
i have a 55 inch curved tv. i have a black line going down the middle that colored lines in the black,what is this caused from.
lisabest0630 의
댓글 18개 더보기
