주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
Reset without apple id
I bought a iPad air model A1474 from our local flea market.... It has been reset but apparently I need the apple id which I do not have.... Can I still setup the iPad or have I been ripped off...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Bricked forever, yes you got ripped off.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
There has to be some way to reset the thing, right? Flash this or replace that...some work-around that might be against a certain company's policy, but his purchase of their product DOA, should Trump any reason in keeping some unbricking trick or hack a secret...
Sure, replace the logic board.
댓글 달기
Ipad Air Wifi only ? what was right months ago is not more actually.
For a reason I don't know (leak or other thing) Idevice Wifi only can have Find My device deactivated for few bucks (10 €) . With FMD deactivated you can reset the Idevice without any problem.
I don't know how it's possible , especially if you consider that in the same time GSM devices are still very difficult /expensive to reset if FMD is activated . I tried to Google that, but I don't find exactly what can explain that nowadays it's so easy to unlock a Wifi device whereas it's so complicated to do the same for a GSM one!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
lokki691369 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 708
