주요 콘텐츠로 건너뛰기
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30 질문 전체 보기
How to repair a USB port that won't accept a USB device?
I tried to plug in a USB cacble to my Toshiba Laptop and it would not go into the purt completely. The connection was not complete as the device I was trying to plug into the Laptop USB port would not work. I am not sure if the problem is with the Laptop or the USB connector on the device I was trying to plug in. How can I identify the correct point of failure? Would it be on the computer USB port or the usb device I am trying to plug in.
Once this is determined, how can I repair the USB connection, or does this require parts replacement?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
droyhull sounds like a mechanical issue with the port since you cannot properly insert a USB cable/device. In that case you will have to solder a replacement USB port unto the motherboard.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
droyhull 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 138
