주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 4월에 출시된 Nikon D5100은 Nikon의 인기 있는 소비자용 DSLR 카메라 중 하나인 D5000의 후속 모델입니다. 교체 가능한 Nikon F-마운트 렌즈를 장착하고 있습니다.
Why won't my shutter work?
I was traveling with my camera and when I went to use it this error appeared.
Error: press shutter release button again. I did and it didn't work.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Have you tried a hard reset?
Press the two buttons on the back of the camera with a green dot by them. For the 5100 they should be "Menu" and "Information".
My D5300 does this sometimes but I know what causes it - I have a portrait battery grip and when the tripod is hooked up, if I pick it up by the camera (and not by the tripod), the weight of the tripod pulls the grip downwards and interrupts the battery connection, so the camera has shut off without powering down. This may be irrelevant to your problem but it's worth knowing.
It could just be that you shutter has reached its end of life. You can check the life expectancy of the D5100 shutter here
이 답변이 도움이 되었나요?
점수 1
댓글 달기
you could try cleaning the shutter gears. following this guide
http://www.instructables.com/id/How-to-f...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Michelle Houston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 4,294
