주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 Acer의 15.6인치 E5-571 시리즈 노트북.
Power switch isn't working?
Hi,
My Acer laptop isn't working anymore. When I press the power button, nothing happens. I looked inside the laptop and saw nothing strange on the power switch, also not on the flex. When I 'short' the connections from the power flex, the fan is working and the hdd runs; but nothing on the screen. After a few seconds is turns off. Could it be the power switch or is it something else?
이미지
Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Try taking it to a computer repair shop.
의 공유
댓글 달기
답변 1개
sounds like there is more going on..
I had the same problem, turns out there was a ram problem to... it had a short circuit and fried the ram.
if the fan starts, there is power. maybe not enough, you ll have to check that. ( measure it out if possible)
than check with new ram.
if still not working :
check with an extern monitor.
Check the flat cable and connection from mainboard to screen.
it is possible the chip on the graphic card is fried..
I was thinking on a dead motherboard , but the fan starts ... so i think more in the other components..
Let us know,
Kind regards
Kevin
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Uas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 779
