주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
208 질문 전체 보기
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
answer is not even about the hinge, only addresses the easy answer
댓글 달기
답변 3개
가장 유용한 답변
Microsoft Surface RT Kick-stand Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
answer does not address the broken hinge!
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
댓글 달기
not helpful--hinge broken & not the stand
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Grant Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 15,557
