Replacing turn signal/wiper/cruise control combination switch
I have the replacement parts, but need some information in replacing the old one.
좋은 질문 입니까?
좋은 질문 입니까?
Simply pull off the rubber cover, using a flat screw driver to help if needed. You will then see a bolt that holds the assembly in place, and a few screws that hold on wires. Remove those, and then unplug the wire harness plug. With all that done you should be able to pull out the old switch. Installing the new switch is just the reverse of this.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 738
