주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Help identifying the CORRECT Logic Board Part #
MacBook Pro 13" Retina Display Late 2013 -...
Howdy folks! A customer of mine has a MacBook Pro who's logic board that was damaged by water. A water bottle spilled in her laptop bag . The red water indicator under the trackpad ribbon connector is positive for water damage. I am looking to properly identify this board so I can order a new one. I thought the BEST thing to do is share a picture of her back cover so you smarties can see for yourselves what model and other machine specific identifiers.
I'd also like to ask if you know where to get parts from a REPUTABLE distributor.
THANKS in advance!
Glen
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Here is your part.
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board 이미지
상품
$219.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
I used http://www.everymac.com to ID the computer via serial number.
Apple Part #: 820-3476-A
@ilabbe - once you do identify a machine, it's best to correct the icon so they can get to the guides
Here's the replacement guide: MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
Correct the icon? I'm not sure what your mean. But THANK YOU GUYS for your help!!!
Ahhhhhhhhhhh!!!!!!! <Screaming like a frightened 5 year old girl> $700 dollars??????? My customer will fall over backwards, BUT... now that I know the part number I suppose I can look elsewhere.
Thanks again!
Glen
댓글 달기
You might want to finish your profile so you can establish yourself as a professional with iFixit to get better pricing. Click on either my icon or Johnathans to look at those profiles.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thank you Mayer!
Yes, that price is way out of line and not at all in line with current prices on the marketplace. I would contact customer support and ask for a price update after you are set up as a reseller. But as you may know, other part sellers sometimes put an artificially low price on a part and then when you go to buy it find it is out of stock. Here's an example : http://www.powerbookmedic.com/MacBook-Pr...
댓글 달기
귀하의 답변을 추가하세요
Glen Comstock 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 13
전체 시간: 1,486
