Why does my laundry come out warm when I choose cold water
When I use my whirlpool washer model W10775514a set it to wash cold, when the wash is done, I open the door and the wash is Warm. I assumed the rinse cycle would also use cold water. What's happening, or how can I set the machine to rinse with cold water too?
좋은 질문 입니까?
댓글 7개
is the pipe fixed to the cold or hot feed at the back
sherwoodys 의
I have a new candy washing machine only fills on cold no hot option. When my washing is finished it comes out warm and smells like cabbage. What can I do?
tanyamallison12 의
I have recently bought a candy washer. A+++ It is cold fill only. When a wash has completed its full cycle/drained, spinned and finished the laundry comes out warm. I've never experienced this before as previous machines have always rinsed out in cold. I'm not sure whether it's the settings on the machine or whether it is indeed faulty. It is plumbed in exactly in the same way as the previous machine so I know there has been no error with connection. Have you found a resolve Tanyamallison12? I'm baffled as to why this is happening! I don't feel like the laundry is clean when comes out warm/hot…could it be because it's eco so uses less of everything?
dpm63 의
Hi @dpm63,
What is the model number of the washer?
If the washer only has cold water hose attached to it then the heat must be coming from somewhere.
My guess would be either a heater in the machine (if it has one) or the motor as these would be the only components that can produce heat.
If the washer has a hot water hose connected, turn off the tap that the hose is connected to and check the wash temp.
If it has no hot water connection check the machine's user manual to see if it has a heater and perhaps specifies that it will regulate the temp. of the water
If no heater that only leaves the motor or maybe the cold water temperature itself.
jayeff 의
I keep seeing these posts, and the experts swearing that the hoses must be switched, or the ambient temperatures are affecting it.
We have a Maytag washer that absolutely randomly switches between hot and cold.
When starting a load, I have to check to see which it's dispensing, and change the indicator to either hot or cold to correct it.
Two loads today, and one rinsed in hot, one rinsed in cold. This is obviously a switch, sensor, or maybe cpu issue.
Derek Jones 의
댓글 2개 더보기
