주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP LaserJet 1200은 Hewlett-Packard에서 생산한 흑백 레이저 프린터입니다.
The paper will not feed
The printer will not pick up paper and/or an evelope
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
this did not fix it. The paper roller will not pick up paper to print. Goes through the motions but does not grab the paper.
의
A piece of paper is stuck in the printer and wont come out.
의
댓글 달기
답변 2개
선택된 해법
Paper dust accumulates over many years of use and coats the rollers thus they slip.
Clean the pickup rollers.
There are special sheets that can be purchased to do this.
Works for my ancient HP LaserJet 1200.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
In most cases, whenever a printer won’t pickup paper, it is usually because of the pickup rollers. I would recommend going to hp.com and searching for your specific printer model. Look for the part lists and find the part number for the pickup roller. Note, most printers have at least two trays. One is where you load most of your paper and the other for the manual paper tray. You want to make sure you change the rollers for the tray that is giving you the most problem.
You can also verify this to be a problem if you touch the rollers. If they’re really smooth, it won’t grab the paper. Rollers should be almost tacky.
Finally, you can try different paper or fanning the paper so that it’s not sticking to one another.
Good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Michael Pierce 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 29
전체 시간: 2,835
