주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
MacBook Case screw won t turn! what can I do?
retina 13-inch early 2015
Hi,
So yesterday morning i spill some coffee on my macbook, screen went black and stop. So i quickly unplug it and begin to open the case. When i did manage to open the case and clean the component inside, let it dry 24h and reassemble it.
It works when plug to the power supply, and it seems the battery is dead.
I want to replace it, with the kit on ifixit. My problem is 3 screw won t turn anymore with my screwdriver. And now i am stuck with a case that i cannot open.
What should i do ?
Thanks your help.
E
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Those are T5 screws in this guide:
MacBook Pro 13" Retina Display Early 2015 배터리 교체
I would use a better driver with a top that swivels so you can press down on it with the thumb or palm of one hand and turn the body of the driver with the other. Also got for the screws that you are having problems with first leaving the others ones in to try to relieve any possible pressure on the bound screws. Here's the type of driver I use for this: T5 Torx Screwdriver
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
enis al 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 757
