Thin red line on TV screen
Hi,
I have samsung UA37D5000 tv. There is thin vertical red line appearing in TV. When I called up the local samsung service guys to check, they said they have to replace the panel and costs almost 23K. I don't believe in their words. Will you be able to tell if it's the real panel issue or some board issue.
If I have to open the TV, it would be helpful to have a teardown guide for my TV.
Attached the picture of the red line on the screen.
Thanks
Rajesh
좋은 질문 입니까?
댓글 19개
I have same issue
karenggivens 의
karenggivens same TV? Same issues? If so then it is the same answer. TAB error.
oldturkey03 의
I have 40" Samsung Curved LED TV. I have the same problem. Vertical line is approx one feet from left side and stationary. Please suggest.
Siyaram Verma 의
I have the same problem. I check the tabs, applying pressure where the red vertical line originated but it did not solve the red line problem. What else could it be?
brennan.moore99 의
so ii have to dismount the back from the tv ???
AMD RX460 Gaming and Xbox 의
댓글 14개 더보기
