주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
I removed the 3g module from my ipad 2 3g and wifi.
How can I restore my ipad 2 wifi+3g gsm when I have removed the 3g module. It stops about midway when installing firmware and never finishes with an error (1).
Maybe there is a chance to use it as an ipad wifi only?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
can you post a photo of the 3g module you removed?
댓글 달기
답변 2개
선택된 답변
No, you will need to put it back.
Unless you replace the CPU and main flash from a wifi iPad so making it a true wifi-only model.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Maybe you can show the picture , what exactly is to be removed to make it work just Wifi ?
Not removed, but replaced using the same part from a wifi only iPad.
The CPU is the chip which has Apple logo and A5 writing on it. The flash memory is the identical 2 large chips. On 16G models one of the spot is left blank.
BGA soldering skills required and replacing these parts can cost more than the device's worth. So it is hopeless.
댓글 달기
Yes u can use wifi only. But u must try fix logic board. U must terminate Some chip on logic board. And firmware update.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
zevaksarturs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 275
