주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
FH error cannot be isolated
get FH error as machine fills. checked flow switch, pressure switch and pump all seem ok.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The repair was the replacement of the input water meter. Although it looked good a replacement solved the error
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
@ivegot2beme as you probably already know the error code can come up with water supply valves that are not turned on, the inlet screens are clogged and the pump strainer/filter is clogged. It can also be caused by a bad drain pump motor. I suggest that you download the service instructions from the bottom of this page and run the diagnostic cycle. Then let us know what you found. Unplugging the machine and leaving it unplugged for 15 minutes will reset it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
larry dalessandro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 153
