주요 콘텐츠로 건너뛰기
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 질문 전체 보기
When was this mower made Murray model # 40702x92c?
When was a Murray riding lawn mower made, Model # 40702x92c
It has a tag under the above model # that says date of manuf. 3063.
It must be coded #. I know its not made in 1963.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
bobthomas1944 you are probably right when you say that it was not build in 1963. But it could have been build the 63 day of 1973.
Murray used a couple different ways of how the date of manufacture was list.
1970's tag format YDDD
1980 and early 1990 tag format DDDY
Late 1990 and Early 2000 tag format YYDDD
Early 2000 on MM/DD/YYYY
Your model number 40702x92c tells us that it has a 40 inch deck was, actual model is 702 and was build for X92C which could be anyone from Walmart to homedepot. Basically it is who it was build for.
You may have better luck by checking the tag or stamping on the engine. Let us know what you find.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I believe it is a julian date. So 3063 is 2003 (the first digit is the year) and 063, the 63rd day of 2003 would be March 4th
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
So then if mine says 2733 when was mine built
댓글 달기
40508x92d what year was made mf date01253
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bobthomas1944 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 60
전체 시간: 6,778
