How do I replace the glass only?
How do I replace the cracked glass ONLY on my LG G4 without replacing the LCD display
좋은 질문 입니까?
좋은 질문 입니까?
If you have some skills you can do that, here is a little help:
해당 답변은 도움이 되었습니까?
I really would not recommend this route. The extra equipment you have to buy, the time it takes to separate the broken glass from the lcd, the risk of damaging the LCD while separating it, and the time it takes to remove the old glue from the lcd is not worth it. After that you also have to worry about permanent bubbles of the new glue between the new glass and the lcd.
해당 답변은 도움이 되었습니까?
You can replace the screen on a LG Stylo 4; I replace mine all the time. HOWEVER, unfortunately you can not replace the GLASS ONLY. You must replace the front end (or face) of the phone. You DO NOT need to buy a KIT. You only need to purchase the Front-End of the phone for replacement. Whichever color you want.
해당 답변은 도움이 되었습니까?
Presumably similar to these LG G3/G2 glass only replacement video, as LG G4 lcd construction is very similar to G3 and G2.
해당 답변은 도움이 되었습니까?
How how much does it cost to replace a front end on LG phone and will it work or could it possibly have problems would it be better to buy a new phone which is expensive or spend whatever your prices for replacing the glass mine is very cracked up please respond thank you
해당 답변은 도움이 되었습니까?
Just sent you a message I'm asking you to send it to my email rather than post it on Facebook cvj 602@gmail.com thank you I want the answer sent to the question I just posted to you
24 시간 전: 1
7일 전: 10
30일 전: 13
전체 시간: 12,023
