주요 콘텐츠로 건너뛰기
New Nintendo 3DS XL로 알려진 Nintendo 3DS XL 2015년형은 2014.10.11에 일본에 출시되었으며 북미에서는 2015.2.13에 출시되었습니다. 대한민국에는 2015.5.1에 출시되었습니다.
20 질문 전체 보기
How to remove top shell of New 3DS XL 2015?
My new 3DS XL 2015 (Limited Edition) came with a small crack in the top shell.
I don't know how to remove the top shell to replace it, as there are no visible screws.
Any detailed assistance would be very much appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Now if you mean this piece
it's very simple.
First remove these 4 plastic pieces that are circled here
that are hiding the screws (nope nothing under rubber stopper this time), then remove the screws. After that simply pry open the shell from where the red circle is
and you're free to go.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Dit this really help?
At least it worked for me ¯\_(ツ)_/¯
Sorry, I haven't looked at this site for a while. How do you remove those pieces covering the screws safely, without damaging anything?
Removing those plastic covers can be a bit tricky especially without damaging anything. I'd prefer using a X-Acto knife or a cutter knife. Just insert the tip of blade to the edge of interior shell and the plastic piece, and gently pry that plastic piece out. This process may leave a cut or two on the plastic piece if you are not doing it perfect(which is next to impossible for me and probably me only) , but it shouldn't bother you so much. Also if the tip of blade broke after prying, you don't need to worry about it too much as it will most likely fall out before you know it, and you don't have to replace the blade as well since all we need is a thin object to get into that edge.
댓글 달기
답변을 추가하세요
ZoeClementine 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 43
전체 시간: 9,141
