주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
Why won't loudspeaker work?
I recently dropped my phone in water, I was able to dry it out and at first the loudspeaker worked but it was very quiet. Then it completely stopped working, so I replaced the loudspeaker. Still didn't work, I thought maybe it was some corrosion on the connections on the charging port, so I cleaned them and still nothing. Now I replaced the charging port and a new speaker and still nothing. What could be causing the loudspeaker to not function?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hello chsash08 ,
Clean the FPC connectors by isopropyl alcohol and check again.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I have tried cleaning with isopropyl alcohol and still nothing. I should add no sound comes out of aftermarket speakers and only a faint sound comes out of the original.
There is probably still some water damage / corrosion on the logic board under the metal plates. I suggest getting it checked by a professional mobile phone technician that does board level repairs for iPhone.
Ok I'll try that thank you
댓글 달기
답변을 추가하세요
chsash08 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 132
