주요 콘텐츠로 건너뛰기
What kind of resister should be used in my laptop?
My laptop fan standard 5v 0.35a, the original sound really loud. It became very light when I plus a 30 ohm resistor--http://www.kynix.com/Parts/868678/HR0130.... But the temperature will getting higher when cpu was busy. Should I change it ? What kind of resistor should be appropriate? Or is there some formula or not? I will be very appreciate if you give me some advice. Thanks a lot!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@amandali this is not a resistor issue but a fan issue. As you have noticed by adding a resistor you are impeeding the fan and running a chance of over heating. Replace your fan.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks a lot. I have already replaced my fan.
댓글 달기
귀하의 답변을 추가하세요
AmandaLi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 61
