What do the bolts look like for the transmission support crossmember
Images of bolts for transmission crossmember
좋은 질문 입니까?
좋은 질문 입니까?
Donnie Kee not quite sure what you are looking for. You need to let us know if it is Automatic or standard transmission. As well as we need to know if it is for the front or the rear crossmember. and which bolts you need to get info about. The actual cross member bolts, the ones that go into the bottom of the trans, or the studs on the riser that go into the trans crossmember.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 133
