주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
phone won't power on.
My phone keeps blinking on and off. And it won't go to the home screen keeps repeating Galaxy Note 4 repeatedly.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
선택된 해법
Have you tried another battery?
That is sometimes a software issue either one of these should work. If you don't want to lose data flash downloaded samsung firmware from sammobile with the matching model number of your phone located in the battery compartment on a label.
Use Odin with the phone booted into download mode and plugged in. Instructions on how to use Odin and flash firmware on to phone are on every download page of firmware from sammobile.
If you don't need to backup data use Samsung kies with firmware upgrade and initialization OR turn the phone off by taking out the battery for a few seconds and putting it back in.
Then hold the power, volume up and home buttons until the white Samsung splash text pops up and immediately stop holding the power button and keep holding volume up and home.
Then it will boot into the recovery menu. And you can use the power button to select and vol up and down to select in the menu. Select wipe data factory reset and reboot phone from recovery mode.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hi I tried all the solutions to turn back on my samsung note 4. The only one that workec was one where you press down the buttons while putting back in the battery, but I can,t find the post on how to do this and I have same problem again
의
댓글 달기
답변을 추가하세요
Robert Marsh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 5,545
