주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Replacement screws, how do I measure them?
Hello guys, this time I am here to know if there is an easy way to measure the screws in a set of replacement screws for iPhone 5s.
Thing is I only need the ones holding the home button bracket (1.4mm #000 phillips); the ones holding the battery connector bracket (1.6mm #000 phillips); the ones holding the front panel assembly cable bracket (1.7, 1.7, 1.3 and 1.2mm #000 phillips); the ones holding the earpiece speaker bracket (4.0 and 2.3mm #000 phillips); and the one securing the back of the display assembly to the LCD plate shield (2.7mm #000 phillips).
So I need to know which one is which.
Any help?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
@caraneday looks like they have been measured by the total length. The only way to measure them properly is by using a vernier caliper. Not an expensive one time investment....
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
@oldturkey03 thanks, I'd thought the same but... how accurately would that be? I mean, there are 1.2 and 1.3mm; and the caliper has an error range, so a 1.2mm might be seen as 1.3mm right? :(
Sure it could but that's a bit high for a vernier error rate. If that would happen then all of them would measure longer. It's never easy to get all of it right when we did not have a chance to sort the screws during dismantle or if they get mixed up. Toughest part of that job......
@oldturkey03 any brand you suggest? a digital ideally :P
Not sure where you are locatesd I'd go with a digital rweadout since that will speed up your work and you do not have to struggle with either metric or imperial
@oldturkey03 thank you so much!
댓글 달기
you’ll need to pay attention to the screw diameter. and a digital caliper such as Harbor Freight sells will save you a lot of pain an guessing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Carlos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 12
전체 시간: 1,673
