주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Why does iPhone 5 charge to 100% then not work when disconnected?
I suspect the battery, but not sure. It will charge to 100%, but then when disconnected it almost immediately stops working. Erratic. When left overnight without charging, it may or may not have charge remaining. Or, when left unplugged would not work until plugged in, at which point it might show 100% or 40% or whatever.
Also, could signal strength be part of the problem? Severe problem occurs in relatively remote locations or in airplane.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
this is usually signs of a bad battery. it refuses to hold a charge. i would recommend to replace it. The battery run about 20 bucks on amazon and about 10-15 bucks on ebay. When removing the battery be careful with not damaging any other parts of the phone as there are some cables laying under it. i would recommend to watch this video for the full walk through. How to replace your iPhone 5 battery
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Possibly. A lower signal strength means that the phone has to work harder to receive data from the source of the signal. In this case it would be the radio towers if I'm correct.
I do agree about what Candido said.
댓글 달기
The battery can cause so much problems and thats the 1st thing i check,??
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks, Coco, I went ahead with battery, I confirm your suggestion.
My pleasure hope you sort it out
Cheers
댓글 달기
귀하의 답변을 추가하세요
John Lozier 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 123
